Hi everyone. Haven't posted here since 2016 when I had some water in my fuel, but since we managed to solve that problem the engine was running great without any issues.
However, this summer this is not the case as I am unable to start the engine at all. Let me explain.
I dropped in a brand new battery, new spark plugs and a new fuel filter. Flushed the carbs just in case there was stale fuel inside. Filled the tank with petrol which previously had a few liters with fuel stabilizer in it, and additionally added 1/4 bottle of carb/injector cleaner. Added some fresh oil in the oil tank.
First start-up procedure was always the same - turn the solenoid valve, pump fuel with the bulb, turn the solenoid valve again. Ignition on, press 3 times on the key and try to start-up.
However, this time this was not the case, even after 1 hour of trying to start-up the engine. It would just barely work for 3-4 seconds on very low idle and will bog down. I tried over and over again and had no luck. I think that probably it is not getting proper fuel flow somehow?
We've checked the compression and it was excellent. Should I disassemble the carbs to see for any issues or maybe the VRO pump failed? Except these 2 things I am not sure what else the issue could be.
Let me know your suggestion in the comments.
Thanks.
Thanks.
