What are the compression values ? WHY? It runs fine when not in gear ----Does spark jump a gap of 3/8" on all leads ? (NEW with no electrode) ----Are carburetors confirmed clean ? WHY? It runs fine when not in gear ---Running with VRO in service and tested ? WHY? It runs fine when not in gear ---Water pump impeller replaced ? (BRAND NEW) ---Are the 3 carburetors all opening up ? WHY? It runs fine when not in gear ----Is the timer base rotating ? WHY? It runs fine when not in gearHow did it run for you last season ?-----You need to post test results here.----What are the compression values ?----Does spark jump a gap of 3/8" on all leads ?----Are carburetors confirmed clean ?----Running with VRO in service and tested ?----Water pump impeller replaced ?----Are the 3 carburetors all opening up ?----Is the timer base rotating ?
Damn you are helpful .... NOT!! If you cant be helpful, move among!! I dont need your snide remarks.I could rebuild your motor without glancing at a manual.----I suggest you find a manual.
