"maybe close to 3.
rule of
"maybe close to 3.
rule of thumb is it will burn 10% of the max hp per hr.
150 = 15 gal per hr........approximatley.
wieght, draft, current , wind, and a few other variables will alter this somewhat.
but it is good to use the 1/3, 1/3, 1/3 rule
1/3 = to destination
1/3 = to home (truck n trailer)
1/3 = reserve
right now the largest tank i have is 12 gal----so i keep a 5 gal premix jug of gas in the boat...............i fish inland on a small to medium lake (robert s kerr) and i have only ever had to add gas once....but i dont drive around too much-----if im bass fishing i might buzz across the lake other wise i use elec motor------catfishig i sit in one place for 1-2 hrs then i will move around some--depending on the bite.
now troller mtr batt i wish i had about 5 when im bass fishing.
if you plan on going to play---have a lot of gas with you and a lot of money in your pocket and hopefully your lake has a floating gas station................water sports suck down the gas, but its a lot of fun.
if you check oput graham's home work on fuel usage you can see there is a sweet spot at cruise speed that will lengthen your trip..........you will have to do your own homework to determine your sweetspot but grahams will give you a major headstart."
