1989 70hp VRO cutting out won't run at full throttle
Fred Cole
My 1989 70 hp VRO has started cutting out at full speed similar to water in fuel I was told the VRO pump could be damaged by ethanol fuel could this be the problem ?? It starts and idles ok ??
You could start by using another known good tank and line.-----------This will eliminate leaks on the fuel supply side.---------What happens when someone operates the manual fuel pump ?--------The VRO pump looks intimidating but it is easy to take apart for inspection.
Yes, ethanol absolutely can eat away at the rubber diaphragms inside a VRO. I've seen this happen before. As racerone has said, it's not hard to take it apart for the sake of inspecting it.
