Hello,
Thank you for reading my first post.
I have a 1989 50hp 3 Cylinder with a rebuilt powerhead with new crank and new fuel system from tank to pump. (original crankshaft driveshaft yoke corroded, compression is 125/126/124 so I opted to replace the crank being the cylinders were in good shape) The motor starts, runs and trolls up to appox 1500 rpm well but bogs down at half throttle, hence the new fuel system and rebuilt carbs.
After confirming that spark was present in all cylinders at the time of bog down, I brought it in to start the process of troubleshooting the ignition. (though there are no signs of backfire, spitting, bucking or typical tell tales of ignition issues)
First was to confirm spark at idle and all three cyl had good white hot spark. next I went to check the carb and ignition sync and this is where I was confused!
I brought the #1 (Top) piston to TDC and then to 0.459 BTDC on the dial indicator. I went to the pointer on the front of the motor and and it was pointing to appox 30 degrees BTDC Shouldn't the pointer be at or very near 0 degrees TDC?? This was well outside the range to adjust the pointer.
Did some research and confirmed the crankshaft model numbers. All is good Crankshaft is Part #8839a2 but after looking it is for a 1989 60hp 3 Cylinder, which uses the same part number crank and flywheel, but could the flywheel have different magnetic placement and marks? I really dont want to tear this motor down again as it is tight and clean and wants to run but right is right... If indeed the flywheel is the issue can I a change out the flywheel to the 60 hp (if different) and be ok with the rest of the ignition system.
Maybe I'm way off and missed something when bringing the TDC around, thought I did it several times to confirm the whacky reading.
Thanks for any help you can give.
