Severini77
Just got a boat and have been redoing the whole boat! Now I’m at the motor it’s a 1989 25hp Evinrude E25ECEB! When I tried to start it, it hit and will run long enough for the fuel to run out real quick like its only the gas you got when I choked it! After trying it a few times a buzz noice came on at the control arm thing! I noticed it was not peeing any so I just installed a new water pump and a new fuel pump! Now when I try to start it! It kinda does the same thing but now it’s getting some water out the pee hole! But it’s not running enough to get a steady stream! What should i try next and what will cause the buzz noise! Is it possible it’s alarming because I been tring to start it and it’s getting hot? I’m stumped on what to do next! Can someone help me
