"I picked up a 1989 25 hp Evin
"I picked up a 1989 25 hp Evinrude that hasn't been run in over a year. Afer a couple of small fixes and a cleaning of the carb, it runs, but not well. First, it seems to be running real rich. Puts off a more smoke than I'm used to and leaves a lot of oil in the tub of water I'm running it in (air screw set to about 1 3/4 turns out). It starts rather easily if you have the throttle lever up but doesn't idle well. It revs fine if it isn't in gear and sounds smooth. When I put it in gear it won't wind out. After a quick search, I see that the schrader valve(?) is the answer to one of my questions...but I have it pointing straight out. Is that correct?
I'm going to call today to see about getting it into the shop, but I'm guessing it will be awhile before they can look at it. If there is anything I can try in the mean time, I'm willing."
