Hi, new to the forum and looking for some help and a possible diagnosis for the rattle I'm hearing when running my 1989 Evinrude 110hp V4. This is a new, re-manufactured motor with new pistons. I'm currently working through the break-in process, but certainly don't want to proceed further until I figure out the problem.
At idle, although the rattle/tick is quiet, I can hear it. It becomes more louder and pronounced at higher RPM's, especially when under load like trying to get up on plane, and while on plane. This is when it's loudest. To best describe the noise, it's a rattle, or a tick coming from around the powerhead area. Although it may be unrelated, my 2 bottom cylinders have much less carbon built up on them, and cylinder 2 has a clean, white plug. These bottom pistons are very clean, like water has been getting in.
What I have eliminated from possible causes:
Pulling the plugs, I've performed the dowel test by moving the pistons down past TDC and checking for play. No issues here.
Checked flywheel for play. None up and down or side to side.
Good strong spark on all cylinders, new powerpack.
Compression 100psi equally on all cylinders.
Prop nut properly torqued and lower unit oil clean.
Carburetors and fuel system functioning properly.
What I DID find was that when rotating the flywheel back and forth by hand, in short movements, I either hear something loose, or this is what it normally sounds like. Here is a video:
http://www.youtube.com/watch?v=1Xsi-2cMvz0
Any help is appreciated. This motor was supposed to be professionally built but unfortunately this is the 4th problem I've had with it. Was purchased out of a reputable re-manufacturing company.
