I purchased a Ranger fisherman with a 115 tower of power engine about 3 years ago. It has always had trouble idling, so about 2 years ago, I got a "tune-up," which replaced my spark plugs, fuel filter, water impeller, and also updated my gear shift box to a newer model. The boat still had problems idling.
During the current quarantine, my son and I decided to take the 3 carbs off rebuilt and clean them. We found that one of the floats was full of gas, the fuel pump was leaking, and the fuel line was leaking at the fuel attachment point to the engine.
After cleaning her up and putting the carbs back on, we tried to set the carbs with the muffs in the driveway. I have to say it was very satisfying to hear her purr in the driveway with my son.
We brought her out to the lake, and she started right up and "idled". However, as soon as we put her into gear, she would sputter and stall unless we gave her more gas and then backed off to a slower speed. If we return her to neutral, the RPMs rev up, and she stays running just fine.
I know the carbs are clean; I do not know if my idle screw settings are correct. I also have read that it could be a weak spark to 1 or more cylinders, or it could be out of timing?
Any help would be appreciated. She does run very well at top speed and starts very quickly once she is warmed up.
Thanks in advance!
Thanks in advance!
