1988 Johnson 6hp lower unit
Stripgear
I need to ship a 1988 6hp lower unit. Shift rod and driveshaft are not needed. I've never had one of these apart before. Can I pull the shift rod and driveshaft and ship it? Will things fall out place?
Look at the parts diagram on this site
Removal of the drive shaft is prevented by the impeller drive key (#36) so you will have to remove the water pump in order to withdraw it.
The shift rod is retained by the clip #32 you will have to remove the gearcase top cover to access this
