Hello all, I am changing the VRO system over to mech. diaphragm fuel pumps on my 1988 150Gt Johnson, and have a few question.
Question 1- Can I use the same vacuum line and just put a tee in to run the second fuel pump? Or do I need to use a second vacuum line from the other vacuum port? If I do have to use a second line do I have to use a check valve in the line?
Question 2- When plumbing the the fuel line do I put the pumps in series and have the outlet of one pump feed the inlet of the next pump and then out the second pump to the carbs? Or can I run one pump to feed one carb and the other pump to feed two carbs?
Thanks in advance for your help.
