timmy66commander
Hello,
Looking for some insight on an engine that runs warm.
Left engine runs warmer about 20 degrees from right engine. Manifolds are full fresh water, elbows/risers(2014) fairly new. Raw water pump rebuilt last winter. No coolant loss over summer of running (head gasket/Heat exchanger ok?). Thermostat (new/160 deg). No blockages on raw water side heat exchanger (took side plates off). I am able to swap the output of each raw water pump to the other engine by moving hoses on raw water strainers and the issue stayed the same (not a raw water issue?)
I used an IR temp gun to look at temps of both engines while fully warmed up and compared. The thing that jumps out at me is the following......
The coolant temp at thermostat output is 20 degrees warmer (167deg) than on good engine (145deg). The coolant temp going to input side of engine water pump coming from Heat Exchanger output is about the same as good engine (122 deg) but after engine coolant runs thru block/intake manifold/cylinder heads it comes out 20 degrees warmer on suspect engine. The left/right side about same temp (one side is NOT hotter than other)
Am I looking at a engine cooling water pump/ blockage in block/bad intake manifold?????
Ideas??
Timmy
Ideas??
Timmy
