It's actually got the SeaRay logo on the cowling, on a 16' SeaRay Seville, but it's a Mercury/Mariner! Anyway, it has been, and still is, a very good engine, but what I've been living with for the past 2 years, is a really rough idle. When I put it in gear, and anything above 2000RPM's, she is really a strong engine. But when I put it back in neutral, to pick up the skier, or pull up to the dock, it is really rough, sputtering, and eventually, will die. I am somewhat familiar with the fact that at idle, this 4 cylinder engine runs on only 2 carbs, and I'm curious if anyone out ther has had a similiar experience, and if it is advised to take the top two carbs off, soak them in carb cleaner, and clean them up really good? Or, is there another less invasive fix to getting the idle smoothed out on these engines? As mentioned, when I give it WOT, or even anything above 2K rpm's, she runs like an outboard motor should, so I don't want to make the matters any worse! Thanks for any advice or experienced information on this...
Wayne
Wayne
