1987 THROTTLE
seajay
1987 JOHNSON 25hp.HOW TO DETE
1987 JOHNSON 25hp.HOW TO DETERMINE IF SPRING LOCATED UNDER FLYWHEEL FOR THROTTLE IS WARNOUT? APEARS TO BE STIFF TO MOVE. BROTHER OWN IDENTICAL MOTOR. HIS HAS LITTLE RESISTANCE. THIS IS A TILLER HANDLE. PULL START.
" seajay;check the armature/ig
" seajay;check the armature/ignition plate bushings under the flywheel,clean and oil- not gease the bushings on the plate. "
