I have a 1986 Johnson 175 outboard with a VRO bypass. I've sunk almost $4000 into it so far and want to make sure I'm not getting hosed. So far on the first round he has installed a new wiring harness, stator, flywheel, coil packs, plugs, all new throttle body and cables, adjusted linkage, and some other stuff I can't remember but it was a lot. When I got it home and tried to start it, it would blow the fuse. After some research I found a wire that I think went to the VRO pump, so I disconnected it and the motor would start but the kill switch wouldn't work and I would have to push the key in for the choke to shut off the motor. Round 2, I took it back he said he fixed the electrical but it needed the lower unit replaced. Thankfully I had an 1987 Evinrude 150 XP that I was able to use the lower unit off of. When I got it home I hooked up the water ears tried to start it and it blew the fuse. I replaced the fuse tried to start it again and got it to turn over but not start and the key switch started rotating freely. I tightened the nut around it and it held in place and I got it started and was able to engage forward and reverse but didn't think to test the kill switch. Sorry so long winded, but I'm trying to give as much detail as possible. So, I took it to the lake tried to start it and it blew a fuse. I replaced the fuse got it started let it idle for a bit took the kill switch off and it kept running and I had to push in the key to choke it and shut it off. I restarted it and when I put it in gear it died immediately. From then on when I tried to start it, it would turn over and immediately die and I couldn't get it started again. So anyone got any ideas as to what is going on and if this guy is hosing me over?
