Hello, I’ve searched and searched for a clue to my problem on here for a while an coming up
short and boating season is close. So the problem is with a 1987 E150STLCU with a jet pump on a 1987 Duracraft with built in fuel tank under seats.
The problem is this,
While running 10-15 miles up river I haven’t had a problem, but coming down river with less fuel the motor will act like it’s starving/choking. If I catch it soon enough and kick it into neutral and feather the throttle a bit I can keep it running. If I don’t catch it in time it will completely die, after its completely killed starting back up is usually not a problem. It will do this 3-7 times or until I get back the ramp and on the trailer. I’ve tried to slowly as well as quickly squeezing the primer bulb once it starts doing it and that changes nothing, it will still cut out and die. Could the diaphragm fuel pump be bad? But what would explain me not having any problems going up river with a full tank?
What I’ve done to troubleshoot is this,
With motor idling in water on boat ramp on trailer, remove cowl and spray fuel lines with carburetor cleaner to see if there’s a crack in fuel lines sucking air which if so the motor would either bog out or rev up, but neither happened.
Replaced plugs, would have to look at which ones I used cause it’s slipped my mind.
Drained fuel tank and let air out before refilling.
Replaced fuel primer bulb and filter.
Other questions I have,
What is the proper water pump replacement number?
What plugs are recommended?
Best way to “winterize” this motor?
Thank you, willing to try any ideas but may be a couple days before attempts are made. Super busy with work, we all know that feeling!
