junior4597
New to this so I am hoping to utilze this as a continued resource
I am looking at a 1987 boat with twin inboard Crusader engines with approx 650 hours. During the compression test we had anti-freeze in one of the cylinders #8 - turned out to be a blown head gasket. This has since been repaired so now I would like the compression test run once again before the sea trial. The original test produced these results:
Cylinder #1 170/170, #2 180/180, #3 160/170, #4 170/160, #5 170/170, #6 165/185, #7 170/170, #8 185/170 these are starboard/port readings
I am wondering if A) these are good numbers on the original test and B) what would good or relatively good numbers be after the gasket has been repaired and the second test. I have been unable to find any usefull info so I am hoping ot get an idea in this forum.
Any help or thoughts would be greatly appreciated. Oh, and would there be any other "typical" tests that shold be run on the engines other than the compression test that I should be aware of and run?
Thanks!
Thanks!
