" I cannot figure this out. I
" I cannot figure this out. I have replaced the thermostat, head gasket, and examined the water jacket and my 1987 15 hp Evinrude is still overheating. Well it is not smoking but the water is very hot and the powerheard is so hot that it actually blew the head gasket. I was told that there may be blockage in the head somewheres but I think so because water is pumping fine? well it looks to be pumping fine? but I do notice that after running at high speads, on the way down, the water pump sputters a bit for a brief moment then resumes back to full power?
I also notices a mild howling noise from the engine. Should I replace the water pump? what could be causing it to overheat?
Albert Ariotti "
Albert Ariotti "
