1986 Mercury 35hp no fire issue
Dealing with a no fire issue on a 1986 mercury 35hp
Testing the stator low speed black/yellow to ground I got 3078 ohms
Testing the stator high speed black/white to ground i got 134 ohms
Testing the stator low speed with DVA black/yellow to ground I got 168 volts
Testing the stator high speed with DVA black/white to ground i got 7.5 volts
Now on to the trigger
Testing brown/yellow and brown/white I got 729 ohms
Testing continuity brown/yellow to ground is OPEN
Testing continuity brown/white to ground is OPEN
Testing brown/yellow to brown/white DVA I get 1 volt
Testing brown/yellow to ground DVA I get .65
Testing brown/white to ground DVA I get .80
I see conflicting information on the trigger DMA specs 1 document says 4+ volts and the other document says 0.5+ volts i have my info on the first chart highlighted
Any thoughts on these results would be great
The above post was suppossed to say
On the coils I'm getting 0.2 ohms across + and - side of coil and 863 ohms across primary side of coil and engine ground
