hello i am keen to get this Bertram back on the water so any help would be awesome (1986 305 mercruiser carby 5.0L)
Have a no spark issue with this Mercruiser
i just put new heads and manifolds risers on and it, has not been started for months, now no spark at the spark plugs,
i have 0 to 5 volts pulsating at the white wire with a green trace terminal at the distributor ignition sensor,
and twelve volts at the white wire with a red trace at the distributor ignition sensor
is this normal i have done the remove white wire with the green trace with ignition on from the distributor sensor and i got the coil to spark when grounding this wire quickly striking reading previous forum`s said thats a fault with the distributor sensor, but i would like to be 100 percent sure before ordering one
