My powerhead was just rebuilt and I took it for a test run yesterday. It ran perfectly for two hours and decide to head in with a big smile on my face and it started making a clunking noise. I immediately shut it down and pulled the cover. It wasn’t hot and the fuel is mixed 25-1. When I got it home I checked compression one found 115 - 118 per cylinder. I checked for play thinking maybe a rod bearing went and found no play anywhere. While turning it over by hand with the plugs out I found the motor catches like there is something stopping it. I can turn it counter clockwise just a bit and continue turning it over clockwise. There doesn’t appear to be any play in the crank. I fired it up and it’s firing on every cylinder and doesn’t sound as bad as it did on the water but still doesn’t sound right. Any ideas what might be causing this.
