I have a 1986 15hp johnson, J15ELCDE. I'm looking for a cylinder head, my part# is 329917. -----I wanted to know if anyone has swapped theirs out with a different head, or if there were any other ones that would fit it?------- The older ones look similar, but didn't know for sure if they would work or not. -------Any ideas or suggestions?----Someone said up to 92 would work. ----- The owner before me didn't tell me about the stripped plug hole on the motor. It was running a little rough so went to change the plugs and clean the carb. When I backed the one plug out the heli-coil came with it. And I don't think the heli-coil was installed properly, once I took the plug out I could see carbon around the base of the plug, like the cylinder was leaking.------ So I figured just get another cylinder head. --------So basically what I need to know is any 9.9 or 15 cylinder head from early 80's to 92 should work?------ I seen on the early ones, the dome of the cylinders were shaped a little different.----Any help or advice would really help!
