I started this thread in the electrical forum because the starter wouldn't turn the engine over. Now I'm moving to this forum because the problem turned out to be hydro-locked cylinders rather than a simple problem with my starter. Ya gotta love boats, there's simply no end to the opportunities to learn things.
To recap the original problem and solution: Bono suggested that the engine was probably hydro-locked so I pulled the sparkplugs and cranked the engine. lo and behold I had water spraying out of at least 4 of the cylinders, maybe all 8. Cranked it until most of the water was gone, cleaned the plugs and put them back in, pumped the gas a couple of times and she fired right up!!!!! Ran it long enough to heat up and dry things out. The engine oil is still nice and clean so at least I know the rings have a good seal, tough way to find out though, I think I would rather run a compression test instead.
Now the question is, where did the water come from? When the problem ocurred I had just finished a 4 hour fishing trip of constant trolling and pulled into the slip nice and slow on calm water, with no following wave which might have forced water into the outdrive. The engine killed as I shifted from forward to reverse which I think is an issue with the shift interrupter that I will have worked on this winter. We poled the boat into the slip, tied off and tried to restart the engine but it wouldn't crank over so it must have immediately hydro-locked. Could the hot engine have sucked water up thru the exhaust manifold and into the cylinders? Or when I shifted into reverse and the engine died could it have forced water into the engine? Either way, is this a common occurance on these engines and outdrives and how can I stop this from happening again? Is the only way to fix it to pull the plugs and pump the water out when it happens?
Thanks in advance for any input, solutions and ideas.
