"motor starts up like normal w
"motor starts up like normal with a prime. Itll idle for a bit, and then start to gallop or surge a little bit and then die out. If I hit the primer when it starts surging, it just prolongs the process. So I can actually keep the motor running by priming every so often.
We pulled the carbs and cleaned them completely.
To me it sounds like an air problem somewhere but with these carbs non-adjustable, It would be in the fuel lines somewhere...right?
We plan on changing out all fuel lines, but I was going to check on here to see what you guys think I can also check.
is there a quick way to explain how to lync and sync? Maybe thats the problem, but with hitting the primer switch keeping the motor running, I didnt think that was the problem.
thanks, any ideas are very welcome. Ohh at full throttle, itll run."
