1986 Johnson 70 HP
Hey guys,
First of all thanks a lot for all the advice and shared know-how provided by this community!
Before posting this thread I read through old posts and tried to find an answer - unfortunately unsuccessfully.
Ok here is my problem:
A few days ago I went on a fishing trip and we wanted to get to an island quickly in the morning so I really revved up the engine.
I would say 3/4 throttle.
After a few minutes an alarm buzzer came on and I immediately switched the engine off to prevent damage.
For about 5 minutes whenever I turned the key (without starting the engine) the alarm sounded again. After about 5 minutes it stopped and I could easily turn the engine on without problems and travel on.
At lower rph that is... as soon as I open up the throttle 3/4 or full the alarm goes off again within few minutes.
Now the oil injection (VRO) has been disconnected years ago and 1/50 mix fuel is being used.
I read in a previous post that the head gasket could be a cause. I bought a compression tester and all three cylinders show almost the same exact compression: 125 PSI.
I never had this problem until I recently changed the battery cables.... however this should not be a problem. I got bigger and better cables and used good insulation material near the motorblock.
Water pump is nearly new and water flow is perfect.
Any suggestions what could be the issue and how to fix it?
I won't disconnect the alarm buzzer though... that's not an option.
PS. Anything under 3/4 throttle is perfect and no problems at all... could probably keep going until I hit Antarctica
Hey guys,
