Ok where to start... The boat idles and revs up fine under no load. But when trying to plane out the boat misses... I have changed plugs, plug wires, coil, dist cap, fuel water seperator, and rebuilt carb... Carb was clean when taken apart to rebuild no ethanol build up. Ive done a compression test and cylinders were all low... No smoke no burning oil or anything to make me think rings... Now i have had 4 different plugs what looks like to me has burnt... On the porcelain about 1/8th" under the tip is burnt off... I have had one plug blow completely out of the socket. The socket was still screwed into the block and the porcelain blew out ... I had never seen that before. I think i have added everything i know of... Please help thanks!!!!!!!
