What exactly is happening with your motor Reed valves seldom go bad. But if you do need to replace them you need to pull the powerhead off of the motor. Then split the crakcase and the valves will be there. Get a Good manual for your motor.
Stop--------Do some trouble shooting.-----The reed valves rarely are the cause of this.-----Post the results of a compression test.----Check spark on BOTH leads.----Does it jump a gap of 3/8" or more , yes or no.-----No insult but if you have to ask how to get to the reed valves this project will take a long time.----What other trouble shooting has been done ?
I need to change the reed valves. The mechanic I took the boat to says it is too much cost in labor for him to do it. Trying ourselves. How do I get to the valves. Stuck at how to get to the crankshaft. The reed valves for this model are in the crankshaft
