Sounds like a bad trigger coil. You can test the 4 circuits with an ohm meter.
Jeff
Post the compression numbers as #4 dont appear to be firing. Have engine overheated? If so I have seen the plastic red dowels melt and allow reeds to shift. Also check spark on lower 2 cylinders..
Is it getting too much voltage from something?High voltage is leaking...no they don't glow.
Sounds like you may need some new spark plug wires...the corona effect is occurring because the wires are not containing the high voltage.
I'm thinking bad ignition coil.
Jeff
Not defending the mechanic but garden hose water pressure can make it look like the pump is working.I recently replaced the impeller and I know water was pumping when I had it running at my house.
