Rjcamel2355
Hey guys, over the weekend I ran across a 17' skeeter starfire 150 with a 150 blackmax.
Oil injection has been bypassed, judging by the anaerobic sealant the motor has been into at one point. Have to do a carb job on it, new needles and carb kits. (Tried just cleaning them), but the top carb is just spraying gas out the front (float issue I'm pretty sure) while the others aren't getting any fuel.
The boat isn't bad for it's age, attached a couple pictures of the boat and motor. (Few soft spots around the drains, and one up on the deck)... but this isn't my first rodeo replacing floors and decks.
Best of all, I got a complete 150hp Parts engine, the boat and the motor (all the gauges, lights and other accessories work) for right at $1500
First question: What is the usual compression for these motors? (From the factory) I know I know.. withing 5#'s is good, but I'd like to know the stock compression.
Second question: The tilt and trim just clicks, I pulled the motor off of it, and it's full of black stuff, but the issue is one of the straps that goes to the spring/magnet thing broke loose (is this fixable?) if not where could I pick one up reasonably priced?
Third question: How are these hulls? How are these motors? I know it's the old 2.0 block (I'm pretty sure) Anything I should keep an eye on?
Fourth question: I have a 200hp lower unit, same year range I know it will bolt to it, reason I am saying this is because when I put it in gear up til I give it a little throttle it will clank/click/ some sort of noticeable noise but once it's past that point it's fine and it just rolls on
Fifth question: What prop should I be looking for? (I plan on adding a 6" jackplate), what speed would I be looking at? (I'm all about getting across the water pretty quickly)
Any hints/tips/tricks would be great. Thanks guys!!
http://imgur.com/a/Kv2uG
