2003hdflstc
1984 Mercury 9.8 H.P. Serial # 6517870. Everything worked perfect, then had to replace impeller. After re-installation (multiple times) motor will not go into reverse and has no neutral. Motor will pull start in supposed neutral position however motor is actually in forward gear. While in this supposed neutral position and moving forwards, engine will only go slightly past idle speed. If I shift into actual forward gear, I can fly like the wind. If I try to shift into reverse, I get nothing, but there is no gear grinding either. Shift linkage feels fine and has expected movements when shifting gears from neutral to forward. Linkage does not feel like it is travelling far enough to engage into reverse. No part of the motor was taken apart other than the lower unit that comes apart with the two nuts and the impeller housing. Attempted to re-install with shift lever in neutral and in forward position with no difference.
