Hi,
just ran my engine with muffs for 7 minutes the starboard side got up to 120 F and the port side got up to 100F at idle. Is that normal? The tell tale was flowing and the water was gtting warmer as the engine warmd up, water was also draining through the front(boatside)block just above the water pump its like an attqchment connecting block housing with 4 bolts another fellow mentioned it was ok as there are quite a few overflow drain ports but wanted another opinion.
I also noticed a milky white flow of oil/water mix with the exhaust coming from the inside if the prop housing I assume it maybe a gear oil seal/ oring leak is it much work to replace this oring/ gasket? It doesn't look like a lot of gear oil loss but I will have to see what itakes to top it up.
Thanks for the help!
Zedde
Zedde
