Donthepressureson
I'm trying to revive an older 2hp Evinrude and can't remove the prop. This little guy isn't in bad shape but after removing the cotter pin, I thought the prop would slide right off the shaft. No go. I even removed the gearcase head and there's nothing odd or broken inside. It spins very smooth and free with no grinding or roughness. But no matter what I've tried the prop won't slide off. Plus, now, I can't push a new cotter pin back into the hole. There seems to be something solid protruding into it just enough to not allow a new pin to slide through it. If anyone has ever run into an issue like this before I'd appreciate any tips you could pass along. Thanks!
Don
Don
