My 84 90 HP VRO Johnson stop running when cruising. I can be going along just fine and then the engine acts like it's out of fuel and stops. The primer bulb is hard as a rock. If I wait a couple of minutes the engine starts and I go through the cycle again. Time varies between shut downs, but is usually about 2 to 3 minutes. I checked the filter and gas flows freely, tried a new hose and changed gas tanks with same results. I did notice the gas level in the filter goes down to the point of near nothin when fast idling the engine. No alarms go off when this is happening. Oil tank is full. The boat and motor were in storage a couple of years prior to this outing, fuel stabilized and engine fogged. Engine starts and runs good otherwise, maybe a little rough on idle. I talked to a Marine dealer in the area I was fishing and he seemed to think it was the VRO pump. thanks in advance for any help.
