sinkingnswimming
"Hello... I have a 1983 bayliner with a volvo (AQ 125B//270)... The timing belt was dryrotted, and came apart when i was trying to start it... When trying to install, i noticed there wasn't a timing mark for the camshaft pulley to line up with (i have the the seloc manual, not much help on this problem)... I removed the valve cover, and tryed to line it up using the #1 cylinder valve positions... It started right up, and ran good at an idle for 2 hours... The next day, it took me 15 minutes to get it running, and ran very sluggish... Prior to the timing belt breaking, it sat up for a winter, and the belt broke while starting for the first time this year... the boat no longer has points, it is now electronic ignition... The boat ran great all last year... I have since replaced the plugs, plug wires, ignition coil, timing belt, dist. cap, and rotor button... Now, i can't even get the boat to run anymore... Has plenty of fuel to the plugs, has fire (not very strong), and has enough compression... My guess is the timing was off a tooth, and now i fouled the plugs... When it ran for the two hours, the exhaust turned the water black... I have done everything i know to do... This is the first boat i have ever worked on, and it is starting to show... If anyone has any knowledge, past experiences, or guesses on this matter, please help!!!! Any and all help will be greatly appreciated!!!! Thanks again, and happy boating!!!"
