snowballak22
I have a 1983 115 hp Mercury Tower of Power inline-6 that has no power after 2700 RPM. I've had the Link and Sink set by a certified Mercury Technician along with the carbs cleaned and properly set. It has set for twelve to fifteen years. All off the fuel lines have been replaced. Fuel tanks cleaned and new fuel added with 50:1 mix. New fuel filter and Mercury fuel connection to motor installed. I know that WOT in neutral is bad thing, but I did it once and it ran up to 4000 RPM. There is 115# compression in all cylinders. From what I have found that there is a Stator that has a Low and High Speed windings and this maybe the cause. Not sure where to go from here. Should all the electrical parts be replaced at the same time (Stator, Trigger, Switch Box (2), Coils (6) and .....) or is one at a time ok. I'm pretty sure that 115 hp Merc still has its original parts. thank you in advance for any help.
