I'm new to boating and owning a 2 stroke. I purchased a 16ft boat with the 115 Mercury heard it run sounded great. After an hour on the water the engine stalled. Took a bit to get it started again I was thinking it was a fuel supply issue. When is was running again it had no power. So after I got it home I removed the spark plugs and found #3 cylinder spark plug had melted aluminum on covering the electrode. I did a compression test and #3 is at 95psi 4 cylinders are 145 and other is 125. Im just wondering is this most likely going to be an engine rebuild to fix this problem?
