What amperage should the starter test? Motor is 1981 Merc 470 (Grady White).
I brought the starter to the auto store and the reading was showing only 75 amps... Sometimes, the starter would not turn over, unless hit with a mallet... but nothing past 75-80 amps.
BACKGROUND:
Ran fine for about a year... then sat about 2-3 months. The boat is weak turning over. I tested battery(s), charged, etc... and they seem fine. Also had them bench tested at the auto store. 910 cranking amps on one... 625 cranking on the other.
Gave it afew cranks and it would barely get the motor turned over. Then it stopped trying to start completely. I hit the starter afew times with a mallet and it tried again to turn over... So I assume its the starter.
I pulled the starter out of the boat and gave it 12 volts... it makes a "clunking" sound when starting compared to a "wing-wing" sound that I am used to... Sometimes it wont even engage, unless you hit it.
Model: Arco 50143... Sells for $225.00 on the net... Anyone know where to get one cheaper?
Thanks,
BACKGROUND:
Thanks,
