Thanks for the help guys... yes racerone the primary wires go to the correct coil.
here is some more information to help everyone understand.
I bought a 1973 glastron t-156 with a rotted transom last year.. I’ve been restoring it for the past 6 months. New transom, stringers, floor all fiberglassed in. The boat came with a 1981 evinrude 90 hp motor on it. I’ve just got the motor back on and everything hooked up. I did clean the carbs, all new fuel lines, fuel pump, filter, and new recirculating lines. First test in the water it died right away.. I found that one of the cdi power packs wasn’t supplying anything to one coil... I bought new power packs and 4 new coils. After I put those on and started on muffs the motor ran great for a bit then started to misfire and back fire. I traced that problem to the kill wire (black/yellow) from stator to the power pack. It had a bare spot and was arcing to ground. After repairing that it ran great on muffs so i decided to take for another test run on the water. I thought all was good because I reversed off trailer , idled out of no wake zone. But when I went to give throttle it just died.. tried like 4 times with same result. Decided to idle back to launch and put back on the trailer.
After that is when I cleaned up the timing base, I have not tried it or even started it since then. The boat is at my dads shop so it’s hard for me to work on through the week. When I say it died I mean it just died. Not bogged down or anything.. to me it acted like timing. Like when you move a dist too far and it just kills the engine.. I’m gonna work on it this weekend and see what I come up with. Thanks for ideas for things to check.
