Robert Laughton
Hello all. I'm a newbi here.
I've had this motor for 7 years and never had a problem - a great motor.
As my family has grown, I bought a bigger boat with I/O.
I started the motor for a buyer of the 70HP boat, and no tell tale water stream. It has always worked.
I dropped the lower, and all seemed fine: good impeller, engaged to the shaft (strange round pin on the driveshaft flat area - I've never seen one like that), a jet of compressed air into the tube going up from the pump confirmed no blockage through to the tell tale outlet. Water pick-up screens are clear, I can see daylight when I look down under the pump.
I put in a new impeller just becausae I was there, and the old one was at least 7 years old....no change.
Any ideas?
Thanks in advance,
Rob
Any ideas?
Thanks in advance,
Rob
