Hi, I have a 1980 4a hp. Mariner 2 stroke outboard,on the gear housing assembly there is a third plug located on the left of the oil level plug (top plug) this plug is stamped ( WASH ) & seems to be a little bit larger than the other two oil plugs. I looked up the diagrams parts list & found that the part # for the plugs is 22-81924m. & three of them were required, but on the diagram itself i can only see two plugs shown. My questions are..(1) is this third plug for flushing the motor & if so what kind of fitting would i attach to it? (2) why isn't it shown on the diagram & (3) if it's the same part # as the other two plugs , why is it a little bit larger ? All help will be very much appreciated thank you.
