1980 85hp evinrude
Walleye23
HELP! I have replaced 2 power packs 4 coils timer/trigger base 3 new sets of plugs starter choke selinoid new fuel pump rebuilt both carbs all omc parts done a link and sync made sure timming was set motor still cutting out acting like its only running on 2 cylinders what am i missing
When you cleaned carbs, did you remove and clean #7 Idle jet (attached link to diagram below)? Also #3 which is your main or high speed jet. If you have good compression and good spark on all 4 cylinders, you may have a fuel delivery problem.
Yes sir I did I have an oil leak coming from the inner exhaust cover about half way down on the right side I don’t think it’s contributing to my problem but needs to be addressed
