CaptainWelder
My old impeller is shot and I don't know which way to put in the new one. All the fins were missing. Any help would be greatly appreciated!
People say it doesn't matter but I have seen them in the housing with vanes bent the wrong way, so I do not subscribe to that theory. Here is what I do Grab the drive shift in a fist with your right hand and turn the shaft the way your thumb is pointing. Put the impeller on with the key installed then lube up the impeller housing with dish soap. Now turn the driveshaft and push the housing down over the impeller everything will be correct. You are going to want to find all the old impeller parts as they could be up in the motor so keep an eye on the temp and waterflow when you start it.
