B
btclark
Guest
" I have 2 questions:
1. Noti
1. Notice the ? in the year of my engine, it's because my model number does not conform to the description in the Clymer manual I bought (covering years 197? - 1990). The manual says to number the leters in the word "Introduces" and match the last 2 letters of the model number to the word to get the year, the last 2 letters in my model number are "EA", there is no "A" in the word "Introduces"?? The serial number on the same plate matches the one I found on a water plug on the engine block. Am I missing something? Nearest I can tell it's a 87 because the wiring matches for that year...
2. Not sure if water is supposed to leak out of a hole in the engine block just behind the drive shaft where the engine mounts to the leg? I can just barely see the hole, it looks rough but maybe a hose is supposed to connect in it and aim the water down? Water flows out with gravity as it drains from the engine.
Any help would be greatly appreciated
thanks
brian "
1. Noti
thanks
brian "
