Moving Violation
I recently got my 7.5 running after about 5 years. I knew I should have replaced the impeller before I started it, but I didn't...It immediately started flowing water pretty good and after a couple of minutes of checking other things, I noticed it wasn't flowing any water. I shut it off immediately. Sure enough the impeller was shot and in a lot of pieces. I fished out all I could find, blew the tubes out with air, removed the thermostat and put air down those passages, etc. I thought I had everything clear. I installed a new impeller and when I ran it again, there was very little water coming out the pee hole; as it got hotter, it began to turn to steam. Back apart and looking for more old impeller pieces (couldn't find any), blew out again with air...same thing. I read on a previous forum about checking a plastic washer at the top of the water tube, and I'll check that. Are there any other tricks or places to look for possible impeller pieces or anything else? Thanks in advance for any info...
