Rjcamel2355
I have a 79' Johnson 140, that I have been at my wits end with for the past few months. I cannot seem to get it to run correctly. Prior to this issue it ran great, and now it just refuses to cooperate with me.
Compression is: 130PSI on every cylinder
Spark: looks great really bright blue, every single plug.
I have changed: Two pistons (got water gas and melted two), timer base, stator, all coil packs, and power packs. I have rebuilt the fuel pump, new plugs, new reeds, swapped the intake, and the carbs ( to test). Crank seals, all gaskets from the bottom up.
I can run the engine on muffs or in a barrel all day long, rev it up, do whatever I'd like to it and it sounds and runs fine (or it did).
I put it in the water, start it, idles fine, sounds great. Once I put it in gear and accelerate 100-200 yards as it starts to pick up speed and get up on a plane it seems like it runs out of fuel (primer bubble is still hard, and the gas is still flowing) but it refuses to start back.
Yesterday, I tried to get it to fire off on muffs, and it did for a short time, but after running ( popping backfiring and all sorts of racket) it died, and wouldn't start back even after cranking on it (working the timing adjustment, and carbs) to try to get it to start back. Nothing.
Holding you hands over the front of the carbs you can't feel much if any air being pulled through them.
Any suggestions would be wonderful, because I am at a loss here....
I have yet to do a cylinder leakdown test on it, and that is my next step.
