RodneyBDunn
What makes my johnson 35hp kick back out of gear after going in full throttle it does great while at ideal speed
Possible bad adjustment or worn clutch dog and forward gear.------------A new to you motor ?
All very good, and certainly the first things to check. Maybe you will get lucky. But then when you get into the real world, the clutch dog and forward gear are worn out.
Any outboard specific hypoid gear oil will do. You should be able to find it at walmart or your local auto part store. fill from the bottom until it comes out the vent hole on top then put the plug in on top and quickly put in the lower plug. Did you replace the nylon washers for the plugs? Now is the right time.
Pull the rewind starter and check the pawl is working correct sounds like it may be not returning to the retracted position all the way when the rope returns.
Check starter teeth are they disengaging from flywheel
