Hi everyone this is my first post on this forum. Ive searched through other threads a few times without finding an answer. I bought a 16ft runabout and this motor came with it, it ran fine the first two outings except for being easy to flood and not wanting to idle for long when tilted to the point where the water intakes were just under water. After it conks out and I drop it back down it takes some cranking to get it running again. I checked the fuel line and it appears free of kinks or restrictions and the fuel pump pumps steadily when I removed the hose and checked its flow. I've put carb kits through both carbs and serviced the water pump while at it. The boat has not been back in the water since the carb kits but it runs and idles fine on muffs and revs fine in gear but I still have the same issue of it dying when tilted to about halfway between down and fully up.
The float setting for drop I got from my workshop manual and they were both 26mm which is about halfway between the specified limits. The float when carb body was upside down I had level with the float bowl edge. I adjusted this by slightly bending the arm between the float and hinge pin without loading the needle. I have seen float settings on this forum but they are not in a measurement I can understand.
Do these motors run on half tilt?
If they do what have I done wrong?
Thanks any help is greatly appreciated.
