johnyrude87
I have a new to me 1978 evinrude 70 hp that runs realy great at wot on a 17 ft specktrum boat I get 32 mph at wot... rebuildt the carbs cleaned them realy well and installed new kits my problem is it his hard to start and wont idle slow enough for fishing will idle all day just rpms are to high I have the factory service manual and have worked on plenty of outbaords in the past I have done the linc and synk not once but 3 times to make sure all linkages a are where hey should be and that well in gear that the roller is not touching the cam at idle but lined up with the bottom mark on the cam just about to touch but not touching and that the throttle plates in the carbs are 100 percent closed at idle the problem seems to me to the motor is getting to much air from somewhere if I put the choke on just barley on she idles/trolls perfect rpms drop to where the should be and will idle all day but with the choke off she is idleing realy high probley around 1000 rpms in the lake and warmed up i don't have a rpm gage just going by ear she also during cold starts wont run with the choke on if I choke and try to start she fires once and then dies then i turn choke off raise warm up leaver she fires right up the idle stop screw is backed way off so I know that's not the problem I am thinking its getting extra air from somewhere maybe bad read valves or a leaking intake manifold gasket any help how to check the reads or gasket would be amazing so thanks for any input oh and also the control cables are new no slack in them went full throttle and back a whack of times to make sure the linc in sync is correct has great compression and spark fresh fuel mixed 50:1 this thing is driving me crazy
