Dirtyhandfordtech
Replaced stator, trigger, rectifier, a few broken plastic pieces. After getting everything together, with wires matching colors, engine back fires and will not run. Used a timing light to figure out which cylinder fires closes to TDC, got it to run decently, high idle, no power WOT. Thought might have a bad Amazon trigger, so I ordered another cheap trigger, different brand with basically same results. As of now, it will run, while running I can’t get enough timing to get to the 3 or 4 degrees, or whatever my manual states, it’s way advanced and don’t have enough room for adjustments, with my timing light dial at “advanced max” marks get a little closer , if I set light dial to 0, engine runs at “max spark” mark with advance arm retarded as far as it will go! what am I missing? Should I buy the 200$ trigger from iboats? Anyone else get bad triggers on for L3? Don’t know much about these motors but I am a Currently certified Ford technician and know my way around “nuts and bolts” any inputs???
