"2 things, clean your carbs, 2
"2 things, clean your carbs, 2nd check the fly wheel. also, take your prop off, and check behind it, and your thrust washer might need to be replaced. also if its air cooled, check your pump, it may be off the air intake, and may be sucking up water from in the shaft. also, when it bogs down, run it slowly faster, until u can get it to rev high and start to work, once you do that, burn it as hard as you can, it will burn all build up in your cylinders. and do a rapid driection change once and a while like, turn left, and crank to the right, it will rev high and wont move for a second, then the prop will bite the water and you wil move again. oh another thing, check your gas tank, if no air is able to get in through, suction willbuild up and cause that, when in idle it wont need as much gas, causing less suction in the tank, gas is like pepsi, the rocking of the waves will make it fizz up and the pressure wont let it take in any fuel. hope this helps, my family runs a marina in Coldwater Michigan, so ahve anymore questions
e-mail me at
[email protected]
or icq at 34995163"
